Does anyone know the distance from the axle centre to the fixed mounting hole? Also, about the cable goes into a pin fixing on the further end which is pulled: Is there anything I could use/make to do the job of the little pin with the grub screw, without having to buy one? I am in the UK you see, postage from U.S is ALOT!! It would be easy with a lathe, but I have not got one.
