If you dont want to weld or drill. I would wrap a piece of flat bar around the frame and bolt it tight.With a 90 degree twist. Then tap a hole and put an adjuster through it. You can notch the flat bar where it meets the axle bracket so it doesnt twist. Or if you want to weld it just weld an adjuster mount.
