hi again,
i just took off a head to a 196 Champion motor and noticed it is a non hemi head and i would like to use it if it fits.
First question i'd like to ask before tearing apart the hemi: Will the non hemi fit the hemi block? i
i would like to install it and so i can buy the 1.3 ratio rockers which are a ton cheaper than the hemi ratio rockers.
A person on a forum has a +.020 piston and milled his hemi head to 18cc and has .080 left over with a .275 camshaft installed.(measured with clay and micrometer) So since HIS set up works i assume i will be okay with my .290 cam ,stock head, and standard length piston and 1.3 ratio rockers with a total lift of .377 (super beast of an engine @ 104LSA)
i wil definitely need to check P2V clearance with clay if it works.
What y'all think?
What y'all think?
