Hi all, I have a 3HP briggs flattie. It has the pulse jet carb, with the tank mounted beneath. It had sat for a long time, I got it with a used Bonanza. Anyway, I took it apart, cleaned it, cleaned the head, cleaned the carb, etc. It runs, but it is hard to start, and it dies a lot, especially when throttling down. The idle is set pretty high. It also backfires when throttling down. I'm not sure if the needle valve needs to be adjusted in or out. Any ideas?
