Nova II with a lighing coil
X"N
New Member
Can you use the Nova II with a lighting flywheel? If so I'm guessing you have to wire it in line with the points still (Basically use the points as a trigger for the nova?
capguncowboy
Are you referring to the electronic ignition to replace engine points? If so, they won't work on Tecumseh engines -- or at least, I was never able to make them work right. There's no way to adjust the timing
