I had the same problem on my old engine. I used Gasket Sealer. from permatex. I smeared a light coating around the crank case, then used a NEW gasket, thens a light coating of sealer on the crank cover. you need to let both surfaces dry for like an hour, before you put the 2 sides together. Never leaked after!
