Check your cylinder on that engine,there is a good chance that it has a steel sleeve in the cylinder.Just use a magnetic pick up tool in the spark plug hole,touch the edge of the cylinder and see if the magnet sticks to the steel. the engine is most likely a three horse power. You should take the carb apart and clean it,be sure to clean all the passages by poking a wire thru them.These are very well made engines compared to the newer ones.
