hey I have a question I have an OldMiniBikes clutch cover and I'm
running a Tomar 2 disc clutch with levers, the clearance between the clutch and the clutch guard are minimaul will there be enough space for the Tomar 2 disc clutch to work?
Grind the bolt heads down to 1/3rd the width. They are only holding the clutch guard so they don't need to be that thick. Then you can add washers to give you more room.
