Took the first rides on the "enduro mini" today.....
HOLY $h!T this engine and 6/1 gearing and 16 inch tires....MAN ...cannot keep the front wheel down! I am shocked!....Its kinda spooky with this much power......unreal.....I think I might re-gear...its soooo touchy hmy:
12 tooth clutch 72 tooth rear sprocket
Mild engine mods.....
Changed to a adjustable idle needle gx200 carb (clone carb Huayi) then....
1. 140 emulsion tube
2. changed main jet to larger size (9MM .036")
3. homemade exhaust/header
4. autolite racing AR3910X spark plug
5. oil catch can on breather
6. Air filter (K and N knockoff )
7.drilled out idle jet (black plastic one with brass insert) took it to 18-20 thou
8. took resistor out of spark plug boot on engine (screwdriver up inside where plug goes),,,,yes its in there ...looks like a fuse....stretch spring and re-assemble
