Performance or stock?
I ripped apart what I believe is a h25 and found something's that don't look stock. Like everything.
Retainers, piston and rod, cam? It has an oil pump setup to lube the journey's where the cam sits on the side cover. Studs in block to bolt down head. Rod bearings. Looks like someone tried to polish the ports. But it has a gear or spline crane end. Didn't come with a flywheel. Any help would be great.
CarPlayLB
I got no help for you!...but that is bad ass! Billet rod? Oil pump? Head studs? Awesomeness! Does it have a steel bore too?
The Quarter midget racers used splined shaft for a reduction drive...maybe a racer modded this? Sure is cool! thanks for sharing!
fistfullabar
Holy smokes!!! That thing is sweet! What going on with the oil pump? Looks like it runs off the cam? Sidecover looks made for the oil pump. Would the governor go there normally?
