Powermate off of power washer
Fatboy04
I'm sure this has been asked a 1000 times, but what size bolt/thread size is in the crank to hold the clutch on. Trying to put one on a Doodle bug (new style)
THANKS
Fatboy04
Thanks, got it on and all line up. It looks good, the air box is a mess now. But here is the trouble runs for 15 seconds and dies. Let it set and the same thing. I had a guy go thru the carb and nothing is wrong , plugged or broken. Help !!!!!!!!
Latent
Air box is a mess? What exactly do you mean by that? How about some pictures because if excess air is going through the air box into the engine it will change the fuel/air mixture of the engine and might cause the problem your having. This is usually fixed with a larger main jet, pilot jet or etube. What kind of carb do you have?
Fatboy04
I opened up the side to get it under the frame, so it's wide open on the inside. It's still at the shop now. When I get it back I can post some pictures
THANKS
