I recently bought a Baja Warrier mini bike used and it has a 196 cc Predator engine. The problem I am having is the engine will start up and run on half choke, but after proper warm up, when I take the choke off, it will die immediately. I have made several attempts at cleaning the carb and cleaning out the fuel tank, bought a new spark plug, put new gaskets on, but still the same problem. Does anyone know what may be causing this? I recently ordered a new carb and awaiting its arrival, but I dont know if the new carb will fix the problem or not. By the way, when I removed the sediment bowl, there was a white chalky substance in the shut off valve area, and there was also some grit in the tank and some water. As I mentioned, I cleaned out the tank and have cleaned the carb with carb cleaner and used a small diameter wire to run through the jets.:shrug:
