FYI for new Predator 212 owners.... After getting the blue mini running I had a oil leak next to the rear fill plug. I could see it leaking between the cover plate and case. Tried to tighten the bolt but it didn't help. What I found was the factory bolts were to long and bottoming out. Put two washers under each case bolt and solved the leak problem. Hope this helps anyone else having the same problem.
