Predator problems
I took out the gov. the cam came out when I took of the side cover. I am sure that I lined up the dots on the cam. So I installed a throttle plate and put the motor back in.
Stars fine, runs fine on choke but dies when you turn of choke. Sounds like high speed lean out ? took out carb. cleaned every thing reinstalled problem still there.Starting to get hold in a hurry. If I missed the mark on the cam do you think that is the issue ? Like I said it runs fine. at higher revs it is not as smooth as it should be. I did not do anything else to the motor other than re-set the valve lash. Any of you guys have a guess as to what the h--l is going on ?
The motor is the 212cc model ( non hemi ) the bike is a Dune Cycle
Thanks for your help..
trinik7597
that's not big enough but that will be the least of your problems if you don't throw some billet parts at that ungoverned motor :thumbsup:
