I recently picked up a very nice HM100 for free off of my neighbor who just wanted it out of the garage. It actually runs nicely, but could probably use a good carb cleaning. It's an iron bore, and gets great compression.
Now if I remember correctly, the Star is a (albeit heavily) modified HM100.
Now by that same token, what are the primary differences? Is there any way to convert an otherwise box-stock HM100 into a Star?
Likewise, what's the parts compatibility between the HM100, and the all cast-iron HH100? I have a very nice, running (almost NOS) HH100, and a couple ok runners (although they are worn & fussy). Would it be possible to build a Star out of an all cast-iron HH100?
Having a few ideas. The Baja Warrior/HH100 conversion is going along very nicely, it would be kind of neat if I could build a tough-as-nails Star out of the engine that's on there now (or just build the HM100 if possible).
This will also run a Comet TAV set up for 40mph max. (maybe even lower once I'm done) The rear tire is going to be very... um... "agricultural" for local off-roading & climbing adventures. Yes, it will have disc brakes. Frame is gusseted & reinforced. Considering a KX/CR/YZ80 front end swap if possible.
I just want to build a punchy, offroad bike to doodle around on.
