Well this past summer I picked up a VT-5 with a brigs on it,the bike was cut up to fit the brigs in it with the original jackshaft still in it,frame was cut at the rear uprights and streched 3 1/2"s. no pics of the mess that it was but it was a mess. I managed to get the frame closer to original dimentions,still about an inch high in the back
.Did a mock setup of it for placement of battery for the 12 volt electric start(the vt-5's never came with electric start),built the battery box/tray and got it mounted up front
. I had a newer style lighting coil laying around and then I had to figure out how the 12 volt starter was going to work with the flywheel with no ring gear,well the ring gears are pressed on so I went and for a flywheel with a ring gear and pressed it off and installed it onto the lighting flywheel
. now it was time to figure out what I was going to do for ignition switch,using the idea of the VT-8 style plate
more to come in a day or so
