Built up a briggs with a 107ss cam with corresponding parts, timing at 34 degrees (alky hl342 tilly) head shaved flat with slight valve pockets cut for .04 clearance with gasket. I've broken a few pull starters and almost my arm before so I don't mind a bit of a challenge but I want a fast bike that's at least moderately easy to start. After really screwing up my arm again I'm going to reduce timing some and prob put in a stock head to help. But still curious if you guys are pull starting some briggs' with 107ss cams..?
