Bought this over the thanksgiving weekend.
Love the look of these Mini's, but the 2.5 hp engine just wasn't cutting it. So here was my solution! put a Predator 212cc engine in it! below are the mods i had to do to get this beast in it!
First thing was remove the air box & exaust to get the engine in there to mark the new mounting holes.
I went with just drilling holes instead of slots. as I'm using the chain tentioner to adjust the chain tention.
After getting the new engine set in place and mounted down i had to modify the air filter box to fit in the frame!
I'm going to ad a screen to the yop untill i modify the whole filter!
next i had to remove the heat sheild and modify the exaust box with a hammer to get it in the frame!
again I'm going to make a custom header, but this works untill then..
the rear fender just needed to be moved back, so i jusy pulled it back and mounted the bolts as shown.
the throttle cable mounted right up with no mods, as did the kill swich wires.
I cut the chain guard and added a ne mounting tab. works OK but will prob make a better guard, as this one is plastic.
this is the finished project for now! this thig will pull the front wheel up with my 240lb butt!
