I have a Genuine Honda GX200 and I would like to do a 3in build. can someone tell me what are some of the challenges I will have with the build as far as having it resleeved? like when you resleeve the block do you have to leave the sleeve raised above the block and cut the head to except the pop up of the sleeve for sealing purposes? or is it as easy as getting the block bored and having the sleeve put in as well. I have seen motors with the sleeve raised above deck height that's why I asked. Or at the end of the day is there a lot more to a 3in motor then this and should I just bore it to the max before you have to sleeve it? I'm really trying to make this build push some power. I have built some good running motors already and haven't had them on a dyno but they have to be around 18hp or so. I'm not totally new to building these it would be my first 3in motor for sure though. thanks guys.
