What size thread is the on the shaft end of the HF 6.5 (Lifan) also does anyone know the threads of the holes on the block (4) where the shaft comes out? Knowing before a hardware run will make life easier...thanks
Hey, I just looked through my nut and bolt bin and want to say they are 8x1.25 metric. I put them through a tav2 and used 30mm long. Not sure what your bolting on but the thread size should be right.
The four threaded holes surrounding the crankshaft are metric. They are 8.0mm-1.25. I purchased a box of 20mm long socket head cap screws and they work perfectly for attaching the stamped steel plate of a TAV30 Torque-A-Verter to the engine.
The center hole in the crankshaft is NOT metric. It is 5/16" - 24
Thanks guy's, now all I have to do is wait for this #%^$@&*()!@#$#ing Tropical storm/hurricane to get by so I can actually enter into a hardware store! You can't even squeeze into a parking lot of one!
