Hello everyone,
Last time I built up my Raptor 2 I didn’t make any sort of thread or mention of it until it was long since complete and running, see the long overdue mention here http://www.oldminibikes.com/forum/more-than-two-wheels-/113893-homemade-kart-belated-intro.html#post954602
The time is upon me, I didn’t learn anything from Jurassic Park, and I will be bringing a dinosaur back to life! What’s the worst that could happen? Begin my second Briggs Raptor 2 rebuild.
I found this one of eBay for a good price and against my better judgment snapped it up. The first impression was very meh, the seller didn’t get very descriptive with the engine history and it shipped with a substantial amount of oil still in the engine which managed to soak every component. I knew it was going to be a tear down anyways. Otherwise everything looks really good internally, stock size steel bore, cylinder has cross-hatching and minimal wear, crank is clean. The only drawbacks were that the tank bracket was broken off, the sidecover crank bearing area is scuffed, and that it appears it has been stored for some time as the aluminum block is pitting and corroded in most areas.
So right now I am just contemplating what I want to do. I want to get the lifter bore area welded. The first welder I took it to tried but he said because of the pitting he couldn’t get any solid welds done. I am going to try and take it to some other people and see what they say. If it can’t be welded up I’ll just toss my 94-SS cam from my previous raptor into this one.
Link to full size here, click to zoom in and see the pitting I am talking about http://i.imgur.com/HZZpi6N.jpg
Other plans are the essential ARC billet rod and flywheel, billet lifters, and shaved eyebrows. Once I get a solid answer of the welding front I’ll make some more decisions.
I am looking for some advice on cam choice. Either for this engine or for the older raptor basically the cam will be used on a block with welded lifter bores. I have been considering and reading about the:
03-SS
- More lift .290 than my current 94-SS (.268), similar duration, higher target RPMs. Sounds like I wouldn’t have the chamfer the lifter bores. I would just have to source the proper 28lb valve springs. This at the moment seems to be what I am leaning towards.
233-SS
- Less lift .233, good duration, 20lb rated valve springs are readily available.
113-SS
- Less lift .242, but loads of duration, excellent top end, fast ramps and harder on the valvetrain. 20lb rated valve springs are readily available.
107-SS
- Big lift .315, but I would have to chamfer the lifter bores and I don’t have the tooling. Where are you guys getting 30-32lb springs? Would I have to go with a dual spring setup? More research is needed.
Thoughts, input, and comments are always welcome! Stay tuned for more updates! Happy riding.
03-SS
233-SS
113-SS
107-SS
