Ray,
How wide of an axle do you have on the bike? i looked for shorter axles but decided to just cut the one i ordered from BMI down. It looks like you have an axle with no threaded ends but has the keyway down the middle, are you going to thread the end of the rods or are you going to use locking collars to keep the wheels on? I know the shortest i found was around 34 inches and the axle on mine is probably around 24 inches and could be a little narrower if i wanted. I used the racing douglas wheels and the aluminum hubs with locking collars and so far so good. I just did not feel comfortable threading the end of a 1 inch axle, nor using locking collars. I sent you a PM with my number.
One other issue i had was welding the bearing hangers to the back of the frame and getting the tracking straight on the sprocket. The way the frame is angled it makes it difficult to get everything straight. I used a wooden jig to get them where they needed to be and it works perfect and tracks straight even with no hands on the bars
The reason i asked about gearing is because trying to turn those big tires you are going to need a big sprocket and mounting the bearing hangers inside the frame does not allow you to run a big sprocket. I started out with a 72 spilt sprocket and could not get the chain and motor to line up because the sprocket hit the frame rail. I ended up using a 60 sprocket and i have less than an 1/8 inch of clearance from the chain to the inside of the frame. It is not idea ratio but the tires in the back are a lot smaller so that helps alot. With the 60 sprocket it has more than enough to throw my fat self off the back. for reference i believe my rear tires are 5-5-10, so only about 10-10.5 tall
One other thing to consider is this bike does not turn worth a flip with the live axle. I suspect with the big tires you are running it will be a challeng as well. Have you considered going with a differential on yours? I literally have to lean all the way forward or put it on 2 wheels to get it to turn. My next one will have the northern tool or surplus center differential on it cause it is a bear on the street.
Keep up the good work and call me if you have any questions. Great job so far.
What color are you thinking?
