First off, it's not a true 24mm nothing. If you look at his pictures, he measures the 24mm at the intake side of the carb, not the bore of carb. Secondly, any of these Mikuni or Mikuni type carbs will fit on a clone ONLY IF you buy the correct manifold. This is determined by first knowing the bolt pattern (distance between both holes) and matching up with the correct manifold.
And lastly, I do not know if this is a genuine Mikuni or not. Someone else with more experience with them will chime in I'm sure. You may not get an honest answer, but the first thing you might do is ask the seller. :shrug::doah:
