Smog pump supercharger
Thepaetsguy
HMMMM...small automotive carburetor with an accelerator pump and a power valve, maybe?
No idea why his carb stuck.
Why is there a serpentine belt pulley on that motorcycle head?
He has a 40 part series on that Barbie Jeep but the only videos I’m interested in in the moment is the ones where he is running boost.
The video before that one shows he welded and extended the camshaft to drive the amr300 the camshaft spins at half the rpm so he needed a big pulley. Amr come stock with a 2” or so 8 rib serpentine pulley
He removed the slide carb and a butterfly carb from a vw worked perfect.
Thepaetsguy
In other country’s gear pumps are used for boost. This thread is my test with a smog pump but also a catchall for nearly ANYTHING I find Interesting in the homebrew boost category. They are also straight through configuration. So like a real supercharger in one end out the other. DB4FA721-A1B1-4FC0-8D55-355F2B4F7D4E.jpeg 294F9FBC-160E-41C2-B694-13F5FFCCC8EB.jpeg 06EAC621-05BD-4CC7-BEE4-DF59E7A4EDB0.jpeg
That really looks awesome!!! Great work!
Please keep in mind...if you want to see boost, you need a load on the crank. You need something to slow the crank enough to allow boost to build up in the cylinder. Otherwise, excess intake causes excess RPM. Maybe install a clutch, a chain and put the chain around something that won't move? That way, you can read your boost gauge as the clutch smokes, and you can allow it to cool at idle.
Redneck dyno.
Thepaetsguy
I do fear the pump exploding during a backfire. I’m gonna lay an old jeep crossmember up against the pump side for the first few times I try to start it. But then again the ride on mower backfires every so often and that Intake is made of plastic..
You've put a whole lot of research and work into this project. It really looks great.
I'm certainly hoping it performs to your expectations.
You will get a video when you fire it up, won't you?
I also hope you put some kind of a load, or a drag on the PTO, so you can see your boost.
Thepaetsguy
I need to drill and tap a fitting for the gauge still I knew I was missing something. And ya I have a yt channel but haven’t uploaded in YEARS.. I will post any videos of it on there.
Also I planned to slap a clutch on it and throw it on the gokart. I have some huge hills near the house that would put it under a load.
I got everything buttoned up BUT did not put fuel in the tank yet. Just sprayed some starter fluid in the carb engine started on the second pull and idled perfectly.
Now I’m gonna move on to just filling the float bowl with fuel so there isn’t to much gas in the mix and once it runs for a bit I’ll move on to putting some actual fuel in the tank and running it.
When the smog pump let’s go I have a starter generator and it’s bracket from a cub tractor. 5hp electric start that turns itself into a big generator would be perfect for a gokart with lights. I’m thinking it could mount the same exact way.
This engine runs so well I just put some fuel in the tank and it started right up. Idles and revs our very smooth I actually didn’t think I’d get this far.
Two problems the slide does get held up the MOMENT you crack it open with the cable. And the overflow drips so I have to lower the float in the bowl so it raises quicker and shuts off earlier. It’s extremely loud
I had a screwdriver handy to set the idle but did not need it. The carb was out of the box correct in my opinion
I went back out and again engine fired right up and it runs just like a normal one.
I mixed a few drops of oil into the gas so the vane bearings have something washing over them. All that’s left is to add a boost gauge and see if it’s making any.
