another tread back from the dead!
Yes indeed! There are several references to disconnecting the governor. And not anything, that I saw in my re-read, that said special flywheel.
I know for certain that you know what you are doing with small minibike engines and I have never got too deep into them. Other than increasing the compression ratio and changing the rocker ratio [on an Intec], and re-grinding cams I don't have much experience. The cam thing was only done when the engine was to operate above the governed RPM.
I am wondering if you will agree with the following: If the question is "How do I get the most bang for my buck in a single hop-up mod?" I say, no question, it would be to greatly increase the compression ratio. Simple for a flathead. No big thing, really, for a overhead valve engine. LEAVE the damned governor alone.
I think, due to the relatively low gas speeds encountered, when the engine is left with it's governor intact, there is little reason to spend a lot of time and money on porting and larger carb....the gain for such things is only realized, in large measure, at RPMs above the regulated 3600.
The engines that I have bumped the compression ratio on were mostly Briggs flatheads and you can't easily get a whole lot of extra squeeze. But boy how it wakes up the little motor. Added performance from idle all the way up! Then there is absolutely no need for a high-zoot flywheel and piston and rod. Reliability of the little motor is not seriously effected and that is a big plus.
Where am I wrong?
