I am in the process of restoring a Taco (hanging engine type) missing the original engine which is a oddity for the position of the serial number stamping. The serial number on mine is stamped on the front edge of the 3/16" thick steel top front fork plate in 1/8" tall letters and reads Z75 K8 700. I have heard of only one other bike with similar stamping on the front edge of the top plate but this bike has one less number than mine and has serial # 155K858. This bike has a WB 580 5 Port engine as originally fitted.
The four slots in the mounting plate on mine are 5/16" wide narrowing the only possibility to a West Bend 820 since the WB 580 5 Port and WB 700 5 Port use 1/4" bolts and the mounting plate would have been slotted 1/4" wide accordingly as I have seen on a friends bike.
It seems logical that the last numbers indicate the engine size but my slots are too large for a WB 580 or 700 5 Port.
Since mine and the other bike have the welded in gusset plated at the steering head I am guessing mine and the other bike are late 1963 or very early 1964 models falling between the Series 1 which had no welded in gusset plate at the steering head and the Taco With Hot Sauce model that had the gusset plate welded at the steering head.
Both bikes have the welded steel collar rings for jackshaft bearings used in 1963-64.
I'm thinking these two bikes were a transition machine and thus the serial number stamping in an odd area on the front fork top plate before normal production got going and stamping done on the top left frame tube just behind the steering head tube.
Since no model name is able to be found I'm going to dub these bikes as "TACO BENDERS" since they are Tacos with West Bend engines.
If anyone else can shed light on this serial numbering system as to amount of number variance and location of stamping on the edge of the front fork top plate please chime in, and better yet, post pictures and description of your bike.
Thank you,
Mike Cates
Thank you,
Mike Cates
