Has anyone changed a TAV 2 backing plate into a chain-to-chain drive? I'm getting up to 15 hp & thinking I may want to run a chain-driven clutch instead of the belt system it comes with from the factory. Seems like I could just run the jackshaft with a sprocket as a driven part, make a sleeve to run the nut against to take up the slack & just run a better clutch in the front on the motor. There are plenty of choices available for a clutch & I could change ratios easily with two chains. More like the original setup, but I don't have one to use now & I do have the TAV that's already in place.
Feels like I'm getting some slipping now, but I've ordered a new belt. The old one is getting tired, but I've read that the TAV2 just isn't up to the task when you start adding more ponies. It was fine with the level 1 setup, but with the motor I'm running now, it's feeling like it isn't holding up to the motor on a hard pull.
Maybe the 7" driven unit is what I need instead?
