If I delete and cap off the primer bulb nipple on the carb body, will I have to enlarge the tiny vent hole that's drilled in the side of the carbs main body?
What symptoms would this cause if I were to leave the tiny vent hole unaltered if the primer line nipple was capped off?
I understand that the primer bulb was also a vent and the only time it sealed was when you had your finger placed on the end when priming.
Thanks.
Thanks.
