I have a fresh rebuilt Tecumseh HM100 and a new carburetor and I am having trouble getting it to run correct. The engine has a stock carb/linkage/governor. It starts and idles fine however once under load it bogs hard and sometimes dies.
Engine has an ARC rod, valves and seats have been ground, valve clearances set. Small amount of porting around the valves
Current carburetor settings: Idle mixture 1.5 turns out
Main jet 2.25 turns out
Any suggestions? Could it be governor related? I have tried to adjust the main jet out 1/8 turn at a time with the same results..
