G germanauto1991 New Member Jul 24, 2010 #1 Jul 24, 2010 #1 Just got a 6.5hp HF engine and need a simple way to hook up the throttle with a cable without messing with the governer leaving it functional.. thanks
S supernova Banned Jul 24, 2010 #2 Jul 24, 2010 #2 Use the google search on the homepage, choose OldMiniBikes not web and you'll find some threads on the subject.............:thumbsup:
R redgokart New Member Jul 25, 2010 #3 Jul 25, 2010 #3 germanauto1991 said: Just got a 6.5hp HF engine and need a simple way to hook up the throttle with a cable without messing with the governer leaving it functional.. thanks Click to expand... this throttle kit can be used on the regulating frame asssembly (aka throttle lever and throttle plate)affordablegokarts: Throttle Linkage Kit these are the instructions Affordable Go Karts - Throttle Linkage Kit & Instructions
G germanauto1991 New Member Jul 25, 2010 #4 Jul 25, 2010 #4 made my own out of aluminum strap :thumbsup:
G germanauto1991 New Member Aug 13, 2010 #6 Aug 13, 2010 #6 Made my own works great with motorcycle twist throttle
J jareeb New Member Aug 13, 2010 #7 Aug 13, 2010 #7 i use the governor arm and the stronger black spring and hook one end to the arm and the other to a block on for the shroud.:hammer:
R redgokart New Member Aug 19, 2010 #8 Aug 19, 2010 #8 germanauto1991 said: Made my own works great with motorcycle twist throttle Click to expand... this gives me an idea :freakout:
