My brand new Tillotson 304WX Alcohol carb is dumping raw fuel. I installed it the other day and all it did was dump fuel out the breather. So, I took it apart and cleaned and it's still doing it. I can turn the Low screw all the way in and it still runs. The high screw starts to lean it out if I turn in at idle. I'm clueless????? It's BRAND NEW. What the Hell? Please help.
Predator 212
ARC +.040 rod
Flat top piston
Billet flywheel
18cc head milled 0.050 ported and polished
Bronze guides
27/25mm SS valves
Black Mamba cam
1.3 rockers
Tillotson 304WX AlKY
fuel pump
Gas tank is above engine with fuel pump then to carb. Don't think I really need a fuel pump????
Predator 212
ARC +.040 rod
Flat top piston
Billet flywheel
Bronze guides
27/25mm SS valves
Black Mamba cam
1.3 rockers
fuel pump
