My experience with Tilly carbs is limited to HD, HR and very little HL use.
Mostly for Snowmobile, Most Tilly carb numbers end in a letter. So I took a guess at HL87A
Which led to very little result, so then I tried B & C
So picking HL87C was only a guess and knew once you saw it, You would know if it was configured the same way.
I have found most HD and HR body's are the same, only difference is how they are set up.
Are all HL carbs 19mm ? I don't know. If I had 3 different Numbers of carbs to check in my hands,
I could make a better guess.
I see the HL87C was used on a Chain Saw, I know very little about Chain Saw's Or how big they would be to use HL carbs.
Good luck in your search
