If you think it's timing, remove the plug wire, or have someone hold the kill switch while you pull it. If it spins over normally, it's timing.
If you think it's compression, including the exhaust valve being too tight, remove the spark plug and pull it over. If it's compression, then engine will spin freely with the plug out.
Joe
