I recently aquired a TS130(I believe). Most of the engine bay has been hacked badly by a previous owner. The main 1"square tubes were cut and extended by adding longer 1" below. My problem is that the engine mount and drive are gone. Does anyone have some good pics of the mount and especially the jack shaft and TQ setup. Any info and measurements would be great.
Also the brake are different then most info i have received. Instead of 2 levers, it has a single lever that drops to a bracket on the frame. After that is an equalizer similar to center pull bicycle brakes. Both bands are hooked to a loop that goes through the equalizer. Does this sound like a factory setup?
Thanks
Thanks
