Hello,
I just bought a Alsport Trisport this weekend. It seems pretty original, but doesn't fit the description of anything I found online. Seems like a lot of 1974 info. I think mine may be older. It has 3 belt type brakes...all independent of each other. One is for each rear wheel and the third is for the sprocket shaft(so it will stop both rear wheels).
Anyhow, mine has a Canada Curtiss Wright KEC 290 engine. When I bought it, it did not run. But, I took apart, cleaned and reassembled the carb (Tillotson) and now it is decent. I was driving it tonight...lots of fun. Its really fast. It's also pretty loud and smokey! I will evantually clock it with a GPS.
I trouble figuring how to plumb it. I couldn't find anyplace that clearly showed the impulse tube going to the metal carb inlet and the fuel inlet being the plastic one on the bottom(when I bought it, there were no fuel hoses).
Also, the wiring for the engine...right now, it is just hanging out. I'd like to install a kill switch. RIght now, I have 5 wires coming out of the magneto area. 3 whites and 2 reds. Also, 1 of each color (one right and one red) go to the ignition coils(so I have 2 whites and 1 red leftover in addition to the wires going to the coils). How do I wire in a safety kill switch?
Also, anyone know what year and model mine is? I know the newer (1974) ones with the CCW 290 had disc brakes...but mine doesn't. It looks factory.
Any help or info would be appreciated.
ALso, you might notice the pull start removed, it bound up so I am using a drill to start it. It is much easier.
Thanks,
Chris
Thanks,
Chris
