Wanted: baja warrior,carbon,heat bolt on jack shaft
I know a lot of you have replaced the bolt on jack shaft unit on your baja heat, warrior or carbon with a tav2 unit.
I would like to buy the parts you replaced: (mounting plate, sprockets, chain, clutch cover, clutch is optional)
Basically I want all the all the parts you took off when you installed the tav2, Let me know, I could use at least 2 of them for some projects of mine.:hack:
