I have two, one with 12/70 which is great for trails as well as nieghborhood cruising, although the DirtBug tires are not too street friendly (too much friction)! The other had 12/66 and is'nt as quick off the line but top speed is way more! For steep inclines I'd reccomend a TAV but I'm not mach of an authority on the subject, I do know how they work and that they are better suited for the mountainous terrain. You can change the gearing to suit your needs, but if you want mega low end gearing for climbing steep inclines top end will suffer! A two speed jackshaft could be your best bet, but would require some serious modification! 12/70 which is probably what you're running now is a safe bet!:thumbsup:
