I've got about 10 motorcycles and one mini. On one of my dirt bikes I left the petcock turned on and it drained fuel all over the floor. My '86 Yamaha SRX 600 has two carbs on a single cylinder engine. I let it sit too long w/gas in the carbs, and now they're plugged up. The bike is packaged compactly, so it's a total pain to pull them for cleaning. Won't let that happen again. I try to run everything regularly. But if a bike's gonna sit for awhile, it gets a full tank of gas w/Sta-Bil added. The full tank helps prevent rusting. I drain the carb(s) and put the battery on a tender, make sure the oil is fresh, and either pump the tires up harder than usual or lift it off the ground if I can to prevent flat spotting the tires. I also change brake fluid regularly, even if the bike isn't ridden a lot. Bringing one back to life is a whole other project.
Here's a pic of the SRX.
