Here's the deal. We both have Baja Warrior bikes. His bike is bone stock with the baja engine on it (196cc??) And a GTC torque converter. Stock 50 tooth rear sprocket, stock rear tire. He weighs about 60 lbs more than me.
Now my bike has a taller rear tire diameter, stock 50 tooth sprocket, it has a HF 6.5 with the NR racing stage 1 hop up kit which includes:
4 degree advance key
Hi flow air filter
Bigger jet for stock carb
18lb springs
I also made a header and installed the Autolite racing plug. This engine with the same torque converter has similar off the line performance, but he pulls away from me in top speed easily. And I'm lighter!! Something is wrong somewhere but I just don't know what yet.
We compression checked our motors, his was just under 60 psi and mine was right about 45 psi (no idea what's normal)
Anyone have any ideas?? My logic tells me I should be spanking him without question.
Hi flow air filter
18lb springs
