Thanks guys/gal
This weeks fiasco had do with me "butterfingers", and the throttle assy. What happens when you drop the plate that holds the throttle assy together......it shatters like glass :censure:
after some tears and whining I dried my eyes, picked up the pieces and tired to figure what the hell I was gonna do. I looked around for some scrap aluminum and didn't have anything in an appropriate size. I had checked both my well stocked local hardware store and even tractor supply when I was picking up some blasting media the other day neither had anything. I spotted some leftover cast pull start parts from a McCulloch I had. The yellow one had a curve to it but the later stickered one is very flat. I figured I'd test to see how it it cut on the yellow first so I cut out the insignia part and made myself a nice little badge out of it :thumbsup:
It cut fine with a cut off wheel so this morning I drilled the large hole first in the stickered one then traced out the remains of the original around it and rough cut it out, fitted it to the housing, and then smoothed it out to match the housing:
I shined it up a little, and tested it out. I can't get it to slip or fail, and its locking an quick releasing very well. but I am sure its a sloppier fit internally only because the original cast part had some slight built up sections inside. I am going to sort of copy them with a little JB weld...or at least try to help ensure there are no problems with it.
