Hi guys. I've tried to find an answer to this but it isn't happening.
HF 6.5 clone. Turning idle screw doesn't do anything. The black lever on the carb that presses against the idle screw doesn't contact the screw at idle. Or if you like, the governor rod is holding the carb open at idle.
If I reach behind the carb and press the black plastic lever against the idle screw, it will idle down and run well at that idle until I release the lever.
I have a max-torque clutch installed. It is necessary to hold the rollbar or the brake when starting so the kart doesn't walk away.
I do have slack in the throttle spring that goes from the throttle lever to the governor underneath the tank.
I have the same situation on another HF 6.5 clone so I do not believe it is a defect in this particular engine on the kart.
Please help and thank you
