In the mid seventies, I put a smog pump (positive displacement, vane type air pump) under the seat of a minibike. I put a pulley on the back tire to run the pump, ran 1 inch rubber to the carb inlet, added a piece of vacuum hose from the tank vent to the rubber hose. This brought the tank (fuel pressure) up to my boost pressure. Centrifugal clutch on the engine to the rear wheel, and a PCV valve in the rubber hose for idle air when the blower wasn't moving. It worked GREAT! Sorry oir the simple description. Ask me, I'll help you.
