Hey guy's,
I got my 6.5 clone motor all short blocked. I'm just waiting to decide what I wanna do with the cylinder head. I have a couple questions some of you may be able to help me with.
1st) What is a safe amount to deck the head when using the AGK flat top piston / aluminum rod combo along with a stock thickness head gasket & still be able to run 91 octane???
2nd) I ordered the stainless valves, retainers & keepers for this thing. But AGK is recommending the use of 26lb springs with the stainless valves. I already have brand new 18lb springs will this be ok??? Why would they require using 26lb springs just because the valve is constructed out of stainless??? Shouldn't spring rates be determined based on the demand of the engine? I can only assume that if they say the stainless valves are "lighter" & stronger then a stock valve, then the lower rate spring should actually be able to control the "lighter valve" that much better??? The only reason I can come up with is they want more spring tension to apply more pressure on the keepers so not to drop a valve by having a keeper come loose or something???
And finally,
I plan on porting the cylinder head, but I would like to see any pictures that might be floating out there before I start playing with the head. I see alot of area for improvement, but at the same time I don't want to smooth something that might be a critical shape for a specific reason. So if anyone has some DIY porting pic's that would b a huge help before I just start cutting away.
Thanks,
Nos
And finally,
Thanks,
Nos
