One of my students build off bikes has an engine that needs parts. Instead of spending hours trying to find everything and buying the wrong stuff I thought maybe all you could help me. Here is the info I can provide.
The engine came off of a Trail Horse, it is a 2.5 hp. I believe it is a early 1970's engine (no data tag). I need a gasket set including the head gasket, crank seals, a crankshaft, connecting rod, piston and rings, governor lever that sticks outside the engine that is connected to the carb, and a set of valves. Any help finding this stuff would be GREATLY appreciated. Luckily the other engine is engines are in good shape. I have included a couple of pictures if it helps. Thanks
