Keying a threaded 5/8" shaft?
I received another 3HP Briggs & Stratton ball bearing motor with a threaded 5/8" shaft and was wondering if I should add a keyway on the shaft.
I have used clutches on threaded shafts before but I usually just drill where the set screws will be and then tighten it down. I would rather have something a little more secure this time and I don't really want to take the engine apart if I don't have to.
Decided to go ahead and key this shaft myself.
Used a Dremel with several cutting wheels stacked to almost exactly 3/16" and a jig.
This is the result.
And here is the jig I used. Dremel was hose clamped to the nylon block.
For a pretty crude jig, it worked very well, a whole lot better than I ever expected. Almost looks professional! :thumbsup:
very ingenious Rob, that should work just fine....:thumbsup:
Thanks. It was scary to tackle this at first. This could have went very wrong and then I would be looking for another 3HP crankshaft.
This good old yellow engine has a lot of history behind it. Originally served as a water pump to clear out our parking lot every time it flooded when we had rain. It was always taken cared of and received regular oil changes. :thumbsup:
May have seen a lot of use over the years but it still runs like the day it came off the assembly line. Now I just got to find a suitable frame for this yellow shortblock as well as the dark grey one.
cool looks good! I never thought of stacking disks. usually i do it when the crank is out and i can get at it with a big grinder. I clamp a straight edge piece of steel and run a cutoff wheel along it . then unclamp and cut the other edge. then grind out the center and clean it up with a dremel.
I originally was going to do this but I wanted a nice clean square groove so that is why I thought about making a jig to do it. I really wanted to avoid taking the engine apart and this worked successfully with excellent results. :thumbsup:
