I need help with a Bonanza BC1000
Hello,
My name is Vinnie and I am a new member. I have a Bonanza BC1000 that I have taken apart so I can restore it. However, the rear drum sprocket is worn out and I cannot find another one. What can I do? The wheels are original, and maybe the tires, too.
Yes cut off the old sprocket and weld a new one on. No one makes a new drum brake sprocket hub that I know of for the go power wheels so your going to have to get a little custom with it
Stutz hardware in Michigan has/had some original sprocket/drums for the bendix. You would have to drill the holes for the go power wheels and rig up some spacers.
I just called Stutz hardware and they had some very similar sprockets. I have 7" rims and they said that their sprockets will not fit. Thanks for the tip, though.
Dave miller has em but they’re a little pricey I think. Also the one Karen posted can work but it needs the correct bolt pattern drilled and from what I remember the bore is wrong size but it is the correct sprocket
