Hey Markus. Good info. Kinda confirmed what I was thinking, these weren't the correct FW & Stator. It was obvious once I saw the stator plate was different. Not sure if you missed it in a prior post but I got the bike running good. I took apart this time to look at electrical issues I was having and because whoever the moron was had the spark plug wire coming out the carb side! Had to be the same moron that painted the engine with 1/2 inch thick white crap (see pics in another thread). I spent hours stripping that crap off and repainting.
Flywheel as suspected is metal, tested with magnet.
My gut feeling is this Hilltopper was from 1972 and as you said FW & Stator were replaced late 70"s. Then sat again until recently when I got it. It started right up first pull day I got bike but ran rough. Put new OEM carb, plug, head gasket, Brake cables, etc etc and got it to run really good.
Was finally down to the electric and then this surprise. Very disappointing as I was trying to keep bike original.
Does anyone know if this was original Hilltopper engine H50-65286H ? From all the research I did pretty sure this is original engine? Like you said "assume nothing" the cover with serial # could of been changed too?
And last thing can you be more clear on how and why this could be dangerous? Only think I can think of you meant is flywheel coming off?
Thanks again
Thanks again
