I am starting to look into wiring this from what appears to be the stock hi/lo beam headlight assembly.
I think these were originally connected directly to the 12v battery and the engines stator AC output was rectified into DC voltage to charge the battery. Makes sense.
If my Tec HM-80 only has a 1 wire lighting coil (3 amp output at 12VAC) it won’t supply enough current to power both the headlight (low beam filament) and the running light portion of the 1157 bulb in the taillight correct?
Also what are the two individual switches on the headlight housing for? I think the high beam indicator lamp is super cool. I want to say this is the original GE sealed beam bulb.
I would like to see if I can restore the chrome finish on the headlight housing.
Not a replate but using some vinegar and steel wool.
