50 mph cat
I trying to get my cat up to 50 mph I bought the frame stretched on craigslist. I bought a tav2 and a 15 in rear wheel for it (still waiting for it), I plan on cutting off the existing motor plate completely off welding a new plate on , adding a hydraulic brake on the sprocket , painting it and making a new seat for it. This is what it looks like now .
Won't take much to reach ur goal of 50 I built a cat eliminator with modified predator motor with 1/4 mile gear it was right there at 80mph contact me if you need any parts
Is this the same Cat that you hit the car with and bent the bars,ripped off the foot peg lol and the same Cat with the cutting board chain tensioner lol
No I bought another stretched cat frame with original cat bars , I probably wont need a chain tensioner with a tav2 :p But if I did get some skateboard wheels that I traded for a beer.
My cat bike does 36 right now and it feels boring 50 to 55 should be fun.
I got my tav2 today and had time to work on the cat . I cut off the old motor mounts , scrub brake, welded on a new plate, drilled the mounting holes , and mounted the tav2 to the predator.
I lifted the motor up with some big nuts :laugh: and have some dom tubing chopped and notched for the footpegs. Now I just need the 15 in rear tire, a 13 in front tire, need the hydraulic brake fixed and mounted, make a new seat, and weld on the new foot pegs . And of course a paint job I am thinking of going with some copper hammered finish spray paint.
Nice work that looks like its gonna haul ass. Dont forget the brakes:laugh:
Thanks guys :smile:
quote You dont see a lot of diaper bag seat covers lol quote
Its a athletic duffle bag that is stuffed with a big piece of memory foam its super comfy and is my only suspension lol :laugh:
Still waiting on the rear tire.
I got the rear tire today and decided to paint it dark hammered gray but I am still working on the brakes. I am having problems with the piston going back and the brake pad falling off any ideas? I can't ride it until the brakes are finished :confused: :confused:any other ideas for brakes on a mini bike with a tav2?
I made a new seat, put the new throttle on, got the band brakes on , and took it for a ride. It feels more torquey than before but it seems to shift before I can do a wheelie on flat ground. If I go uphill it will wheelie, kinda bummed that I lost a lot of top end the bike feels like its going about 30 mph, far from my goal. Is there anything I can to to get more top end with my tav2 , would moving the spring to position 2 or 3 fix my problem?
45t
I like that seat a lot, is that and old leather pillow cover?
As far a as the speed your looking for, I think 50 mph is doable with your set up. You might have to play around with it and get it dialed in.
I had a 6.5 hp clone with govenor removed on my son's Cat 250X and pulled off 41 mph hauling my 200lbs. So you should be able to get a lil faster on yours if you can dial it in.
thanks I made the seat from an old purse that my grandma once owned and I stuffed it with high quality extra dense carpet padding. I hope I can find away to make the tav2 go up to 5000 rpms.
