I've searched and searched and found that I can easily remove the low oil sensor issue by just snipping the wire but I can't seem to find any info on what that small square module does that is connected to the oil sensor. It appears to me that after cutting the sensor wire I should be able to remove it as well and just connect the wire from it to the kill switch directly to the block. Can anyone confirm or deny that?
